Phydeauxman's avatar
Phydeauxman
Small upright freezer on inverter
Would love to replace the small frig in my outdoor kitchen with a freezer that runs off the inverter when going down the road. Anyone have any experience with something similar?
  • Naio's avatar
    Naio
    Explorer II
    For my Edgestar freezer has a surprisingly huge startup load, which my current inverter cannot handle. (Surprising bec it is only 67 watts once it gets going.)
  • tenbear wrote:
    Years ago I tried running my refrig in a small TT off an inverter. The inverter would stop working after about 4 hours because the TT didn't have adequate wiring to keep the battery charged. I never did attempt to improve the wiring. YMMV.
    RV fridge ?
    That was 200~300 watt load, 18~25 amps from the battery to power the electric heater
    Not the same thing
  • Years ago I tried running my refrig in a small TT off an inverter. The inverter would stop working after about 4 hours because the TT didn't have adequate wiring to keep the battery charged. I never did attempt to improve the wiring. YMMV.
  • Thanks for the posts. This is a low priority item for me but wanted to see what others might have done to solve the problem. What people have said about getting fridge cold before leaving is sufficient for us as well because so far we have only kept beverages in the fridge. What I would prefer if I did anything would be to replace the fridge with a freezer to keep more food and use an ice chest for beverages. I have seen people do the chest freezer in the basement but we don't have the room for that. May look at putting a chest freezer in the bed of the truck under my Bak-Flip cover.
  • Another similar post.
    http://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/28440401.cfm
  • We bought a Webeco (Dometic) compressor refer that can be cooled down to zero. Runs on 120VAC or 12VDC. Works extremely well. I have it in the basement of our fiver plugged into both power sources. It automatically switches to 12 volts when we are on the road.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
