ItsyRV
Feb 28, 2019Explorer
According to Dicor, the lap sealant can take a month to fully cure. Until it does, the curing process could be stiffed by reintroducing certain chemicals that impedes the curing process such as the adhesive from Eternabond tape. Although it appears it will eventually cure, you may have a slightly weaker spot where the Eternbond adhesive curing was interrupted by the "seeping" of chemicals from the tape to the lap sealant. But in the big picture, it's not something that would really impact intended use under normal conditions.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
