Twain's avatar
Twain
Solar for keeping batteries topped off.
Interested in a small solar solution to keep 2 24 group batteries topped off while the RV is in storage. Right now I disconnect and haul the batteries to the house and charge them monthly. The RV is in full sun all day long in central FL. I'm guessing that 10-20 watts might be enough???
Of course the more I research solar, the more the plan grows. When these batteries die I will go up in size to at least 2 group 27 or possibly 2 golf cart batteries if they fit in the compartment.
  • DrewE's avatar
    DrewE
    Explorer III
    It sounds as though you need the solar to not only keep up with battery self-discharge, but also powering parasitic loads in the RV. If your battery is running down to 40 or 50 percent capacity after a week of sitting, that's maybe 40 Ah of charge gone in a week, perhaps a little more, or about 6 Ah per day. 10W would definitely not be enough, and 20W likely also would not. I'd suggest somewhere around 50W minimum...but I'm very far from an expert on these things.
  • Sitting varies from 2 weeks to 2 months. After 1 week of sitting the batteries are down the 12.1 volts. There is no disconnect switch, which I found unusual.
  • How long does the trailer sit unused ?
    Mine sits for about 3 months.
    I throw the disc. switch in the coach and just let the E450 sit.
    I run the truck and gen every 30 days or so for about an half hour.
    That should be as effective as your method, only you don't have to remove the batteries.
    If you have AGM batteries, they can sit disconnected in place without attention for 3 months with no problem.....IF they are fully charged going in.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
