KD4UPL
Jul 16, 2018Explorer II
MC4 is the standard. Most panels are installed on buildings where there are 10s or even 100s of them. In those installations cutting and soldering would be way too complicated. If you modify the panel in any way, such as cutting off the connector, it will void the warranty. If you're not worried about that then go ahead. If you think you might want the warranty don't cut the wires or modify the junction boxes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
