mike-s
Jul 17, 2018Explorer II
KD4UPL wrote:That's an awfully broad statement without knowing exactly which panels he intends to use. Because, it's not true in general.
If you modify the panel in any way, such as cutting off the connector, it will void the warranty. If you're not worried about that then go ahead. If you think you might want the warranty don't cut the wires or modify the junction boxes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
