Almot
Jul 20, 2018Explorer III
Bpounds, big panels from 180W and up are twice cheaper per watt than 100W panels and are very common today. 280W are often same size as 220W, 300W is slightly bigger. Solar Blvd is a good source.
Big panels are 24V nominal, this means you need to use MPPT controller, more expensive than PWM, but in the end $/watt cost of 600W system will be the less than 200W.
For sustainable living on solar you want at least 300W. Having more wattage won't hurt, because in rain and low overcast solar output drops several times.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
