bpounds's avatar
bpounds
Nomad
Jul 16, 2018
Solar MC4 connectors - needed? Why?
I'm in the early planning stage of doing a solar install on our fiver. I see the MC4 connectors and combiners are commonly used, and I wonder why, and if there is a reason why I could not just solder and seal the conductors between panels, and even between the array and the leads down to the controller. It doesn't seem like a common thing to have to replace a panel. At least not common enough that you would need a quick disconnect. I understand the connectors also make it idiot proof as far as polarity, but so what?
The MC4 connectors are cheap enough, so that's not an issue, but it just seems like a lot of fooling around with pins and housings, for no benefit. I like soldered joints when practical.
Opinions?
  • bpounds wrote:
    I'm in the early planning stage of doing a solar install on our fiver. I see the MP4 connectors and combiners are commonly used ...
    I'm thinking you mean MC4 connectors. :@
  • I have 3 panels which had pigtails with MC4 connectors. I removed the pigtails and wired direct to the terminals in the junction boxes on the back of the panels. It's easy enough to get to the terminals if I need to remove a panel. Any connector will add a little resistance. The fewer connections the better.
  • I think the industry is trying to standardize on connectors that are appropriate for the voltage/amperage of solar systems. DIYers have a tendency to go cheap and under size connectors and connectons.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
