wanderingbob
Apr 01, 2015Explorer II
Running the refrig on "electric " is the most inefficient way there is , You will have to run the 12 volts thru an inverter to get 110 volts A C . Leave it on propane , twenty pounds will run twenty days or so !
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
