westend
Apr 03, 2015Explorer
So, if you use those plastic mounts, you have 24 screws to remove to remove the module? I would suggest to use four pieces of aluminum angle and four pieces for the module, use a single pin in each mount. If you want to remove the module, just pull the pins.
What I found with my single module is that I don't even want to get up there on the roof to change the tilt angle (easy to do), much less remove it for any reason.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
