consumeratlarge
Apr 03, 2015Explorer
westend wrote:
So, if you use those plastic mounts, you have 24 screws to remove to remove the module? I would suggest to use four pieces of aluminum angle and four pieces for the module, use a single pin in each mount. If you want to remove the module, just pull the pins.
What I found with my single module is that I don't even want to get up there on the roof to change the tilt angle (easy to do), much less remove it for any reason.
Yes, that's true. I have a very cool cordless driver that would do it quickly. And I like the quick release idea for tilting the panels. But I went ahead and figured I wasn't going to really do that, so I went this way for 2 reasons:
1. Bigger footprint, spreading the load on the roof. I'm just not experienced enough with putting massive things on thin plywood to feel good about the mounts that I would use in a static install.
2. I don't exactly what would make me want to remove the panel, but maybe getting to the junction box on the back, cleaning debris, inspecting the roof, I don't know. But, I know that if I glued it down to the roof, for instance, I would then, without a doubt, have to move it.
Like you, I don't want to go on the roof to mess with the panels. Although, there is something measurably gained by cleaning the panels of dust, I've found.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
