GordonThree
Apr 28, 2016Explorer
Gdetrailer wrote:
Save you money and put it into solar and a nice generator.. A 300W-400W windturbine is merely a decoration which will only net a couple of watts of power unless you are in a storm. A generator will charge up your batteries at a much faster pace and is far more reliable than wind power.
x2 for generator. Provides those charging amps day, night, rain or shine (or blizzard), etc. If it runs on the same fuel as your vehicle, the gas can for the generator is also an emergency reserve for the vehicle.
My mind is split on solar. It's a neat technology but the cons outweigh the pros in my mind.
Pros: quiet, rooftop install is always working if conditions are right
Cons: need to keep panels clean, need to tilt or loose 30-45% output, needs full sun, doesn't work at all nights, raining, snowing, etc.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
