Good afternoon, I'm in the process to setting up a solar panel setup and my fuse/breaker box is inside under the stove and my batteries are currently in the front outside. I was wondering if it'...
Yes you can. Just be sure to connect the cables from the charge controller to the negative and positive bus that connect to the battery. That will be the where the largest cables are going to the battery.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
