Good afternoon, I'm in the process to setting up a solar panel setup and my fuse/breaker box is inside under the stove and my batteries are currently in the front outside. I was wondering if it'...
Charging will be compromised from very small to unacceptable. Wire size, length and amperage (ie solar size) are the main considerations.
Do you have other wire routing options? On my sons 5er we ran the wire down a front closet to the controller next to the battery located in the front for example. No visible wires inside.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
