Good afternoon, I'm in the process to setting up a solar panel setup and my fuse/breaker box is inside under the stove and my batteries are currently in the front outside. I was wondering if it'...
My fifth wheel is set up the same way; breaker panel below the reefer on the rear wall and batteries all the way forward. (2) 140 watt panels on the roof. I came down the reefer vent to the breaker panel and it works very well. It may not be the best solution but, not much else you can do.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
