joel1ExplorerSep 01, 2017Solar to Panel?Good afternoon, I'm in the process to setting up a solar panel setup and my fuse/breaker box is inside under the stove and my batteries are currently in the front outside. I was wondering if it'...Show More
corvettekentExplorerSep 01, 2017Why not mount your solar panels on the roof at the front of the trailer? Then you wire run will be much shorter.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
