joel1ExplorerSep 01, 2017Solar to Panel?Good afternoon, I'm in the process to setting up a solar panel setup and my fuse/breaker box is inside under the stove and my batteries are currently in the front outside. I was wondering if it'...Show More
MrWizardModeratorSep 01, 2017the fuse goes between the panels and the solar controllerbe advised with most controllersyou are supposed to connect the batteries first, then the solar panelsif changin batteries or doing any thing like thatdisconnect the PANELS FIRST, Then the batteries lastpanels connected to a controller with no batteries can burn out the controller
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
