Boon_Docker
Oct 03, 2018Explorer III
camperdave wrote:Bill.Satellite wrote:
Keep in mind that you will need to swap our your 2 12V for 4 6V batteries. If the math makes sense, they are good batteries.
No, dual 6v batts are a common and almost direct swap (just a bit taller) for dual 12v. You just wire in series instead of parrallel.
You should have about the same Amp Hour with a pair of 6 volt as you would with a pair of 12 volt.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
