Bill_Satellite
Oct 04, 2018Explorer II
RedRollingRoadblock wrote:theoldwizard1 wrote:mike-s wrote:
A GC2 battery is 6V and typically over 200 Ah (the common Trojan T-105s are 225 Ah, but current Interstate/Costco ones are labeled 160, which is the low end).
Where did you pick up that information ? Everything I have read is that the Interstate/Costco GC2 batteries are 225Ah.
I was at Costco today in the metro Portland, OR area. GC2, 210 Ah on the Interstate label, $93 and some change.
So, 1 6V battery rated at 210 would give you 210 ah in 12V when you connect 2. If that's all you need then you are good to go. However, if you had 2 12V batteries that each put out 210ah then you would need 4 6V batteries to provide the same number of AH's.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 03, 2026
