Boon_Docker
Oct 04, 2018Explorer III
Dusty R wrote:
I always looked at it this way. If I was out in the middle of nowhere with 2-6 volt batteries in series, and 1 went bad I would be dead in the water. Where if I had 2-12 volt in parallel and one died I would just unhook it, I would have only half as amp hour, but I would still have some power.
Dusty
Out in nowhere how would you charge up the one good 12 volt that just got discharged by the bad parallel 12 volt?
So unless you had some way if charging the good 12 volt you would still not have power.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
