Boon_Docker
Oct 04, 2018Explorer III
Bill.Satellite wrote:
So, 1 6V battery rated at 210 would give you 210 ah in 12V when you connect 2. If that's all you need then you are good to go. However, if you had 2 12V batteries that each put out 210ah then you would need 4 6V batteries to provide the same number of AH's.
Those would have to be awful big 12 volt batteries at 210ah each. Each one would weigh at least 120 lb.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
