donlb's avatar
donlb
Sound System Advice
I need to replace my amplifier/receiver. Just need good stereo and connect to flat screen TV and DVD player. Also, would like a pair of 'small, inexpensive' speakers that can be easily mounted. With the vibration that occurs in our Class 'C' when travelling, a solid and durable amplifier is desired. Amplifier and speakers should be $150 or less, if possible. Suggestions please.
  • "Good stereo", "solid and durable" and a budget of $150 is going to be tough. Check over at Crutchfield for items that will fit your needs.
  • I use a Sony DAV-X1 similar to a Bose 321 system. You can pick them up on Ebay for around $150. used. They run close to a $1000. new. Or you can find a used Bose 321 system. They sound very good in a RV but are not Blu-ray just reg DVD. They have 2 very small speakers and a sub. You need to make sure it includes the cables and remote when buying the system, reg cables will not have the proper ends.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
