Hondavalk
Sep 24, 2015Explorer II
SRockwood wrote:Hondavalk wrote:Swampman597 wrote:Hondavalk wrote:
Does your A frame have room for a mount.
http://www.etrailer.com/Trailer-Cargo-Control/MaxxTow/MT70214.html
Thanks but it won't work either. I have a deck built on the back using one of the 2" receiver hitches on the bumper and two more 2" receivers bolted onto the frame. All this becomes the base for a platform thats almost as wide as the back bumper and I don't want to add the additional weight of a spare tire back there.
Just in case you didn't realize it but that mount is designed for use on the A frame up by your hitch.
He's got a 5th wheel... :)
OP:
I'd just steal the mount for a 3/4ton+ pickup from a junkyard, then weld/bolt in support crossmembers for it. Mock it all up in the driveway, then bolt/weld the whole thing into place under the trailer.
:S That would make a difference :B
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
