Vintage465's avatar
Jan 02, 2018
Splitting up the batteries and charging
I want to install a second battery dedicated to running the forced air furnace. I know there are going to be a lot of suggested alternatives like generators, catalytic heaters, rent a space with hook-ups, more covers on the bed etc. But suffice to say, I want to be able to run the existing Forced Air Unit(FAU)while boon docking w/o having to fire up a generator. I am going plan on adding a second battery and connect the charging up to the existing Samlex 300w/30a system. I will tap into the existing 8 gauge (8ga) wire and then add two disconnects downstream of the tap. That way I can either charge the "Coach Battery" or the "FAU Battery". Couple questions. Currently I run two 6v in series. Makes me think the second battery for the FAU should also be two 6v in series....thinking I read somewhere that you shouldn't mix one 12v with two 6v in series? Also, related, but not really detrimental to the entire situation is that I will almost certainly add one more 150w Samlex panel to get me 450w of charging. Other than personal preference, does anyone see anything really wrong with my tentative plan? I attached a little sketch plan.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
