Chris_Bryant
Oct 29, 2014Explorer II
The "tow rating" is completely meaningless, and is usually based on a stripped model with a driver, nothing else. You need to find the Gross Combined Weight Rating, then actually weigh your truck as it will be while towing. Subtract the trucks weight from the gross combined figure- that will give what you can tow. That figure is often thousands of pounds below the "tow rating".
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
