AH64ID
Oct 29, 2014Explorer
Your limit is going to be RAWR, and the axle is only rated for what the door tells you. All 1500's are limited to 3,900lbs, and if you haven't weighed your truck with the family and current TT (guessing not based on the brochure numbers being quoted) you will probably be surprised.
The tow rating is based on a single 150lb driver and nothing in the cab/bed (floor mats, bed liner, etc).
Dry weight is a fairly useless number, and I bet you are over your RAWR/GVWR with the smaller trailer already.
If you want a bigger TT you probably need a bigger TV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
