cs2kplus's avatar
cs2kplus
Sub Floor Replacement
I am replacing all rear floor of camper due to water damage. It starts with thick plastic stapled all along bottom (not touching this), followed by a 1/8 luan type filler, then 2x4's on their sides, then blocks of styrofoam and finally 1/2" plywood.
I want to replace the 1/8 luan. Does it have to be a specific material? I believe its used for moisture absorption. Having a hard time finding something.
Advice?
Thanks
:R
  • Look at the underlayment designed to go under vinyl, looks very similar to luan but has xx's in a pattern for nailing pattern. I have used this and luan. Both are Not designed to get wet, but I think the vinyl underlayment would be more stable.
  • cs2kplus wrote:
    @westend...ah..yeah that sounds better. The problem with 3/16 (which I have seen) is that I am joining to existing front floor (which is fine). So the stackup height needs to remain the same. Unless - the is stuff you speak of can be compressed to 1/8?
    @Teachers Pet....see above.
    I was wondering if this would be ok?
    http://www.homedepot.com/p/Unbranded-1-8-in-4-ft-x-8-ft-Tempered-Hardboard-832777/202046928?N=5yc1vZbqm7Z1z0z6jh
    No, Lauan won't compress. Since you are starting from the bottom and working up, I would get a sample of each piece of the flooring puzzle and see how they stack to your existing floor. Plywood, nominal 1/2", is not. It's typically 15/32". Another thing you can do is where the new floor meets the part you are keeping is to screed a filler along that seam. If the new floor is within an 1/8" or 1/16" of the old, a feathered seam will make the transition invisible. Actually, when I install vinyl, I fill all of the seams, knots, holes, etc. with a light filler, anyway. I don't want anything to telegraph through the vinyl. If you are overlaying with laminated flooring or carpet, this is all a non-issue.
  • @westend...ah..yeah that sounds better. The problem with 3/16 (which I have seen) is that I am joining to existing front floor (which is fine). So the stackup height needs to remain the same. Unless - the is stuff you speak of can be compressed to 1/8?
  • Luan is found at the box stores as "under-layment" for vinyl floor coverings over the plywood sub-floor. It is normally sold as 6mm or just under 1/4".
  • You don't want "moisture absorption qualities". You want moisture repelling qualities. Conventional Lauan board sold at the big box stores is a metric dimension, close to 3/16". It has the outer plies made from a tropical wood similar to Mahogany. That is a good thing as the faces hold up to moisture well. To insure it's durability for your project, seal it with conventional wood sealer like urethane or spar varnish. I have 25 sheets of it in my Starcraft and it is weathering well.
  • @GENECOP....having a problem finding luan 1/8". Home depot and Lowes has - but not in stock for some reason??? I am sure I can find elsewhere. But...really not sure if it matters what it is. Seems like just a sub flooring over plastic. But - I've heard it has some moisture absorption qualities. The floor won't get wet.....but I think the plastic below may attract it?
  • It's probably standard Luan.......not designed to deal with moisture.....There are other options out there but I would stick with the original materials......the floor should never get wet....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
