enblethen
Jul 12, 2013Nomad
You should check the neutral (white wires) connections in the rear of the circuit breaker panel.
The breakers are over heating causing them to trip. You should not switch to larger capacity. The breakers are sized for the wire and the load.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
