Bobbo
Jul 12, 2013Explorer III
Increasing the amp rating of a breaker risks a fire. A wire that can only safely carry 20 amps is now being asked to carry 30 amps, a 50% increase. That translates into too much heat, melted insulation, and ignition. The breakers are matched to the wire size.
The only exception to that is you can always DECREASE the amp rating of a breaker compared to wire size since that doesn't increase the possible amp draw over insufficient wiring. When I upped the wire from my converter to my batteries from 8g to 4g, I left the breaker size the same as it was for the 8g wire. I wasn't going for increased amperage, I was merely going for a decrease in voltage drop.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
