time2roll
Jul 31, 2013Nomad
Also if the 30a main and 20a a/c breaker are a tandem breaker they may build a bit more heat together. If you have a second 20 amp breaker further down you can swap this with the a/c. That is swap the hot wires that come off the terminal. This will separate these two and reduce the heat a bit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
