sprint180's avatar
sprint180
switch protector ???
In our new camper the awing, water heater, and light switches are right at the top of the entry steps. Unfortunately they are just at the height my 15 month old granddaughter loves to push the buttons. How have you all fixed this problem. I know there is someone out there that is crafty and figured something out. I thought maybe somehow I would hang a picture over it but not sure. Any help appreciated.
  • I framed around the awning and slide switches with some square trim. Then I used double sided velcro to hold a piece of paneling over the switches. Out of sight, out of mind for a 2 year old granddaughter yet still accessible by pulling the panel cover off.
  • Might want to use some of that Command Tape from 3m and skip the screws unless you don't mind the screw holes once the cover is gone. Or use the screws to fill the holes leaving the heads showing. Then you could replace the cover when the next GC comes along.
  • Thanks for the wonderful advice. I think I will try the thermostat cover. Moving the switch (8 of them) is way above my skill set. I'm just a old (young) grandma. I can screw in a few screws though.
  • Any add-on device will likely look like an afterthought. If it were me, as suggested I'd install a new switch somewhere. I'd pull the switch out of the wall and disconnect the wires. Then extend wires up the wall to a new switch location - that is, assuming you can get wires to the a new location. If the wall is an interior wall, it will be hollow and easy to get wires into. If on the end of a cabinet, you can tuck the wires in a corner of the cabinet where you won't see it. You can always reconnect the switch in the future if desired.
    Maybe you could wire the old switch to a loud buzzer, that way switches will probably never get touched again, lol.
  • Actually a separate switch is not a bad idea. Most likely all those switches have a common feed. Locate that feed and install another switch out of her reach. Then she can flip the switches all she wants. She probably loves hearing the awning open or the lights go on. Most likely wonders why some wonderful person installed them at HER level.....Dennis
  • With a plastic cover from the thermostats that are used in offices that have a key to open.
    navegator
  • Just lights? Let her play ;)
    Maybe put her in charge of them?
  • I would fix it with a switch! Just kidding.
  • Yep! Kids love to push buttons.... Funny though ... so do adults! Enjoy the little one as much as you can. They grow up way to fast. My daughter had her 4th baby yesterday! Hard to believe!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
