down_home
Jan 14, 2014Explorer II
Old-Biscuit wrote:
Yep....very cold temps in an rv will cause flooring to shrink and crack.
Same can happen to ceiling covering at seams where ceiling trim is and can also cause the wood faux trim to shrink away/lift up.
Vinyl flooring cracked/shrunk will need to be replaced.
LOTS of choices.
Enjoy your new flooring :B
Another thing to watch, at home, is the garage door seal, on the bottom. It will shrink after installation especially when it gets cold and for some time from other causes. Lets all kinds of bugs in. I left two inches on either side and made certain what was in the track was not stretched.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
