ScottG
Mar 06, 2014Nomad
Yes, a new drive shaft and you'd probably want one of the none computerized trannys. Maybe a 700r4.
You might be better off just installing and overdrive unit. That way you the engineering is all done for you. My FIL went this route and it worked great, fully automatic just like it was an AOD trans.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 16, 2026
