AM_Allan's avatar
AM_Allan
Thermostat wiring delema
I have a 2012 Komfort 5th wheel with a single zone Dometic heat/cool thermostat. My complaint is that the lowest heat setting is 60 degrees. That's just too warm for overnight or short-term maintenance heating. I have found another Dometic single zone (min 40 degrees) that would appear to be a good replacement, but it comes with a plug-in connector and mine is hard wired; 8 wires soldered right into the circuit board.
Has anybody else encountered this problem? Do I need to take it to a service center?
  • Do you mean the single zone lcd:
    Those all should have screw terminal hookups, and offer a 40 degree f low heat setpoint.
  • Why not replace it with a battery operated Home style Thermostat ?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
