Atlee's avatar
Atlee
Explorer II
Mar 25, 2021
These are a few mods I have done
The first is my usual analog thermostat change out. To me, those things are useless. Since this new trailer has a 2 wire, heat only thermostat, I got a Honeywell PRO 1000 Heat Only residential style thermostat.
  • My next modification was reclaiming lost storage space under one of the dinette seats. Early models of my floor plan had a cabinet door allowing use of the end of the dinette seat. Later models took this away. I didn't add a cabinet door, but I still reclaimed the space for storing some sleeping bags.
    This fist pic is the bench seat with cover off. At one end is the water pump. At the other is wasted storage.
    Added support under the seat.
    Partition in place.
    Bench seat board cut in half.
    Wire for "hard wired" propane detector was just running across the floor loose. I duct taped them to the side. The Styrofoam pieces are covering the protruding detector mounting screws.
    Finished split seat board.
    Cushions in place.
  • This mod is replacing the dealer supplied Grp 24 12V battery for a pair of GC2 210 amp/hour batteries from Sam's Club. I bought the double Grp 24/GC-2 battery box from Amazon.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,403 PostsLatest Activity: Apr 13, 2026
