agesilaus's avatar
agesilaus
Explorer III
Oct 02, 2019
Thinking about beds.
OK for years I have been mighty irritated by the fact that my feet stick way out on an RV bed. I finally looked into the problem only to discover to my Horror that rv mattresses are six inches shorter than standard mattresses. Thus leaving my feet about 8 inches out in the open.
So cogitating on this situation I first thought that maybe I would put a plywood extension under the mattress and dump the rv abomination, buying a standard queen sized mattress. Then the whole end of the bed would stick out another six inches into the bedroom. I could live with that.
But further thought came up with this plan. I'll build a 6 inch wide plywood box the width of the mattress. I'll install that at the head of the mattress, sliding the mattress down six inches. Add plywood underneath at the end as a support. Then add a standard length topper over this covering the box and mattress. Indeed the box at the top could be a secret hiding place.
We have a topper but it's too soft and I want something a little firmer.
What do you guys think of this idea?
  • On our last 5er, we put a full size mattress in it, and then put a 5" piece of foam between the "headboard" and the mattress. My thinking was that all it has to do is hold the pillows up.
  • Wouldn't work in our RV as the bed is in a slide and pushes up against the closets when closed. Longer mattress and plywood box would keep it from closing. Maybe it's time to buy a new rv -- some of them do have regular queen size beds - some even king size.
  • DutchmenSport wrote:
    Sounds like it would work. Make it with a locking device and you could have a secret hiding place for money, guns, valuables.
    Don't know your layout, just make sure if you go with a longer bed that slide-outs aren't affected.
    Not a problem our only slide is for the dinette. I plan on some cabinet making anyway for slides in the pantry and under the sink. So this will go right along with those plus I'll have some hardwood plywood on hand then. Now you gave me the idea I have a box those basement door locks I could stick one on the box.
  • Sounds like it would work. Make it with a locking device and you could have a secret hiding place for money, guns, valuables.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
