opnspaces
Aug 08, 2024Navigator III
Sounds like you're talking about a Gear vendors Under/Overdrive unit. They were really popular back in the 80's when we only had 3 speed transmissions because they basically doubled the amount of gears available. Link to Gear vendors Looks like they are 3,000-5,000 plus installation.
I believe in transmission cooling, but would say it depends. Does the motorhome have a transmission temp gauge? Is it having a heat problem now?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
