EMD360
Dec 28, 2021Explorer
I bought a similar TPMS through Amazon. The only thing I noticed is that the numbers on the caps don’t match the setup. But I’ve had good luck with the readings being accurate. I had a nail in a rear tire but both duallies on that side were worn out from running so low. I had not driven it anywhere but the tires had flattened more than once it appears the weight of the coach damaged the tires. I bought two new tires and set up the TPMS again now it’s in the shop. Getting Koni shocks and a helliwig sway bar and new rear brakes. And an alignment that seems to causing the shop issues. But having the TPMS is another step in the right direction.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
