Esacnj
Dec 29, 2021Explorer
I have had a system for many years on 2 travel trailers and a 5th wheel. I selected the brand because the sensors were the smallest and lightest. I ran them on standard rubber valve stems and never had a problem. I decided to add them to my dually since it had no sensors. That was a mistake. I had them cause a problem with the inner tires on both sides deflating the tires. The TPMS supplier said that they were successful on most valve extensions. That was not the case as I tried different extensions. Apparently the added weight of the sensor creates a problem with the long stem on the inner tires. I have since had metal stems installed but am now reluctant to run the sensors on them also do to their length.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
