SJ-Chris's avatar
SJ-Chris
Explorer II
Dec 24, 2021
Tire Pressure Monitor System (TPMS) --- Great add-on
With the seriousness of proper tire pressure, load capacities, etc, I'm surprised that RVs don't come standard with a Tire Pressure Monitor System (TPMS). After having multiple RVs for the last 4 years, I have learned the importance of proper tires and tire pressure. I have also had multiple times when tire pressure went low (due to a nail) and also multiple times when the rear inner dually tire was flat and very hard to notice (before installing a TPMS).
Thankfully, I haven't had a blowout that resulted in steel belts of the failing tire thrashed underneath the RV doing lots of damage (which I hear is not uncommon).
I wanted to share with all of you just how easy and inexpensive it can be to add this feature to your RV.
Here's the one I choose and installed in each of my 3 RVs...
(...looks like I need to adjust a couple of tires and their pressure)
You can find it on Amazon for less than $80 and it takes less than 5 minutes to install:
https://www.amazon.com/gp/product/B08HMZZFRF/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
(Plenty of others to choose from, this is just the one I selected)
It has a small solar panel on the top of it, so when it sits on your dashboard it stays charged. It only turns on when it feels vibration/movement (or you manually turn it on). To install, you simply screw each cap on your 6 tires (in proper order). I didn't bother with the locking mechanism as I don't believe people are looking to steal these items.
Gives me great comfort being able to know my tire pressure at a quick glance. There is an alarm that beeps to warn you if the tire pressure drops below a preset amount. Safety first! If you don't have such a monitor on your RV I highly recommend it.
Happy (and safe) Camping!
Chris
  • Grand Design offers a TPMS on some of their models, but there are complaints about its operation, and not being very reliable.
  • RV and/or chassis manufacturers aren't going to add anything that costs extra unless the feds require it or the market demands it. I expect TPMS' will be offered as a factory or dealer installed option at some point first.
  • Installed a TPMS on my 5er over 10 years ago. Never had a low tire. But it gives peace of mind to be able to see pressures and temps any time I am driving. Know right away if a tire starts losing air during a long trip. And much easier to look at a screen than get out and manually check pressures.
