ranferg
Jun 25, 2026Explorer
Tire Pressures
Hello I have a 2017 Coachmen Mirada. It weighs 18,340 lbs. fully loaded. 6040 in the front and 12300 in the rear. I have read every forum out there as well as anything I can find on google or you...
the drivers door frame what tire pressure is recomended for that vehicle, if you are on the same load rating and size then that tag is what you should use. if you changed up the tires load range and went to a different sized tire then you might have to email the tire maker and ask them for their load inflation charts. pick the psi that is proper for the weights, and I always add 5lbs to that for a safty margin.
Thanks! A bit new to the class A motorhome thing so I think I'll stick with the sticker pressure and quit worrying/wondering about it.
Ya, realistically steel sprung utility chassis are not built for comfort and when you get in to med/heavy chassis vehicles, tires aren’t really in the comfort equation either.
Unless you were waaay over sized for tire capacity you’re best just sticking to the sticker or tire sidewall in general. Because you’re also likely close to your gvw rating.
vs say a heavy duty pickup what could be operating at significantly less than gvwr.
Time for a CAT scale weighing? I think so.
what for? its a motor home, nothing has sugested in this post that it is over any tire weights. he was in fact, looking at dropping the pressure in the tires to match the amount of weight he was below the tire capacity.
