SJ-Chris's avatar
SJ-Chris
Explorer II
Feb 13, 2022
Tornado flush added to black waste tank...
While working on a different black tank issue, I decided to finally add a black tank flush system. My hope is that it will keep my sensors clean and accurate. It seems like most times when I dump my black waste tank the 1/3rd and 2/3rd sensors have been staying "on" and that forces me to get out the hose and wand, run it all through the window, down the toilet, etc to get it clean (what a pain). Hopefully this works...
I picked the Tornado tank flush system. You can find it here or on amazon...
https://www.campingworld.com/tornado-permanent-tank-rinser-with-remote-connection-28091.html
In order to drill the hole in the rear of the tank (so it is blasting water towards the drain), I needed to remove the rear outer tire and the forward flap.
There is a template that comes with the system so it makes it easy to know exactly where to put all the holes.
Apply lots of silicon and fasten the unit to the tank...
I added an elbow to reduce hose strain.
I ran the hose to the drain valve area (seemed like a good place), ziptied it up and out of the way, and cut the hose to length.
Here's a modification I made to the Tornado system that should help me and hopefully others can take advantage. I noticed that the spray pattern was not ideal for my tank and sensor setup. The head of the device that is inserted into the black waste tank spins so it sprays water pretty good. Here is what it looked like out of the box...
I felt like it might not hit my sensors as much as I want to get them clean. So I took the smallest drill bit I have and added two more holes in just the right spot so that the water will hit the area it was missing. I tested it all (uninstalled) on my driveway and it created the pattern I was looking for. Here is what it looks like:
Total time to install was probably about an hour with much of that involving jacking up the RV, placing jacks (for safety) and removing the outer dually tire.
I'll let the silicon dry and then test it out.
If this works as I hope it does, it will be so nice keeping my tank clean after dumping and more importantly my sensors clean without ever having to bring a hose through the window and wand down the toilet again.
Happy Camping!
Chris
Update: I was doing another black tank project and accidentally broke the outside connection of the Tornado Flush. So I bought a new one. When I used the same silicon sealant it started having a small leak at the sealant connection. I tried a couple times (with water thankfully) and it kept leaking just a little. So I removed it, cleaned off the surfaces, and used Sikaflex-291 after some research. Here is the link:
https://www.amazon.com/gp/product/B089SDNLF6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Marine grade. Made for "below water line" connections. Zero leaks and I feel great it will stay that way. Good luck!
  • rhagfo's avatar
    rhagfo
    Explorer III
    I guess I for one just quit worrying about how full the tank is.
  • I hope you have better success with your Tornado than I did. After about a year the bearings seized and would no longer turn. You could hear it getting worse and worse over time and then finally would no longer turn at all.
  • Nice job. While I beleive tank rinser do help. Nothing seems to work as well as a Flush King. Internal OEM tank sensors are not the best idea from the start.
    Tank sensors overall are in place to give to give novice RV'ers peace of mind that their RV is not going to overflow with poo.
    However the tank sensors realy are not necessary, the tank will give you audible and visual signs when it is full without sensors.
    After RV'ing a few years you learn to observe the tank is getting full warning signs.
    I instaled a tank rinser on my first RV, but since then I have come to realize they are not necessary
  • Bobbo's avatar
    Bobbo
    Explorer III
    Nice job. However, (there is ALWAYS a however), I am not sure I would want the weight of the brass fitting always attached to the plastic Tornado bouncing up and down on rough roads. I am afraid that over time, the plastic will fatigue and break. I would personally prefer using the plastic hose with a large loop permanently zip tied into it to perform the same function.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
