Bill_Satellite
Oct 24, 2015Explorer II
I don't believe anyone said the Jack was bad. The reality is that the Sensar is better. If you use a Sensar plus the Sensar Pro then you have the better antenna and it takes less than 10 seconds to point properly. I don't remember Jeff's results but I think he also compared an incorrectly pointed Sensar with an improperly pointed Jack (yes, the Jack is directional as well).
Both antennas work and both antennas do a pretty good job and both have limitations. I have the Winegard Razar Air which is more like a Jack but is less directional but just as limited on the VHF channels.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
