- Ron3rdExplorer IIII used one of the swing arm mounts on my old trailer. I was able to find a wood stud with a stud finder and it was a simple job using about 1" wood screws on the mount's base. Those 22's are pretty light nowadays.
- GaryWTExplorerI would say that you would not want much longer than that, the walls are thin. Find a stud and go for it. When I did this in a previous trailer, I found a tv mount that had 2 holes, one on top of each other so they went into the same stud. It was 2 pieces so it was easy to slide the tv off the piece on the wall. When travelling, I did not trust it so I would put the tv in the middle of the bed and hang it back on the bracket when we arrived to the campsite Good luck.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
