CA_Traveler
Oct 23, 2019Explorer III
Yes series connected panels, thanks for the correction.
Voc increased with lower panel temperature and exceeding the Voc can damage the controller, hence a colder weather consideration. The Morningstar String Calculator will check this. You have to use a MS controller but you get the panel results.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
