Vintage465's avatar
Oct 22, 2019
Up grading my Solar Conductors
I've been working on running new solar conductor from the roof to the pass thru near the batteries. Here is what I've done. From the existing Zamp Combiner box(to be replaced) it I fished the #4 conductors over to the drivers side wardrobe in the trailer. Down the inside of the wardrobe. Since it's pre-wired there was good access in the overhead cabinet above the bed as there is an inspection/access panel to the pre-wire.
Then I had to run it exposed in the short space where the night stand is. I took some poplar hobby wood from Home Depot and cut it to fit on my table saw and then "skinned" it with the "panel matching" tape that ORV uses to trim inside corners and splices where the light paneling meet. It came out OK. Not 100% proud. My mind visualized it one way....my 60 year old body being tied up in knots in that little space got it done another way! Lucky thing is my C-Pap Machine goes down there and it's really never visible. At the top of the trim on the left, what looks like discoloration is actually a reflection from that chrome 12v outlet plate. That's for my C-Pap..................Yes I know "TMI"
  • Looks good enough to me. Actually, there's a good chance that this is the most neatly installed and best secured wiring on the entire RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
