myredracer's avatar
myredracer
Explorer II
Feb 12, 2015
Upgraded from standard LED pancake lights
Our 2014 KZ Spree 262RKS TT came from the factory with the old basic pancake style of light fixtures in LED. We really wanted to get puck lights but the factory said they couldn't do it in the 2014 model because of the change to an arched ceiling and the weight of puck lights. Not sure if that makes sense. I used to design lighting systems in commercial and institutional buildings, and to me, the pancake style of lights seem so outdated, plus just about every RV has them (unless they have puck lights). There had to be another option...
I came across an alternative at an RV show, made by Kaper II and I ended up replacing all the lights on the ceiling with them. They have roughly the same footprint as the pancake lights so they cover any screw holes. They are very light and only about 3/4" thick. They have an opal diffuser so are a lot less glary than the prismatic lens on pancake lights. The diffuser is edge lit with about 30 LED strip around the perimeter. I added one next to the kitchen counter since there was no pancake light there and it was a bit on the dark side. I also added a 2nd one in the bedroom. Illumination level is about the same as the old lights and in the bedroom is much brighter which is want we wanted. The Kaper II lights are available through RV dealers and the last time I looked, could not find them on their website.
I removed all pancake lights that were under cabinets and replaced them with LED puck lights. I mounted a couple of the pancake lights in the pass-through which really help finding things when it's dark outside.
  • geotex1 wrote:
    Those are Diamond Group/Kaper II's Slim Light series and that should be the 11" oval model which has 72 diodes. Really nice fixtures, but are rather spendy for fixtures that do not have circuitry compliant with FCC. Local enclosed trailer manufacturer carries their line, and I have them in my car carrier and they produce terrific light. In your camper, you might need to install chokes to deal with the interference to TV/radio.
    Luckily, we have no problem at all with interference. I did test one at first before installing them. At $65 per, they're sure not cheap. Maybe there's better sources for them?
  • Those are Diamond Group/Kaper II's Slim Light series and that should be the 11" oval model which has 72 diodes. Really nice fixtures, but are rather spendy for fixtures that do not have circuitry compliant with FCC. Local enclosed trailer manufacturer carries their line, and I have them in my car carrier and they produce terrific light. In your camper, you might need to install chokes to deal with the interference to TV/radio.
  • The receipt is still on my desk and shows I paid $33.55 Can./each for them last Feb. when our dollar was about on par with USD.
  • Those look pretty interesting. I found them online for about $65 ea.
    Is that close to what you paid?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
