RoyB
Jan 13, 2014Explorer III
I will be doing something similar when I start experimenting with my HYDRONIC Heat mod for my OFF_ROAD POPUP setup that will use the hot water heater for heat source replacing the propane furnace..
I want to be able to run my hot water heater from my on-board INVERTER for a PLAN B backup when PROPANE may not be available...
I will probably go with a smaller wattage 120VAC heater element however...
Roy Ken
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
