TNGW1500SE
Jun 09, 2016Explorer
That's a lot of work for 1 little heater.
Here's what I did:
I found the wiring going to my A/C behind a removable wall panel that covers the shower plumbing. The wire was long enough that I could cut it and still wire nut it together so (after turning off the breaker) I put in a junction box and tapped in with another 12/2 (with ground) wire. I ran that new wire to a 20 Amp outlet that I put in the wall. I plug the heater in there. If you use the heat and the A/C at the same time, you're going to trip the breaker but why in the world would you run them at the same time! All done it cost me about twenty bucks to do. No extra cords to plug in because it all runs off my 30 Amp cord. Problem solved
Here's what I did:
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
