westernrvparkow
Jun 09, 2016Explorer
That is not true 50 amp service, as others have pointed out. Furthermore, some 30 pedestals are protected by an additional breaker at the service entry panel. Mine were until I upgraded to all 50 amp pedestals. If that is the case, all you will do is trip that breaker and you won't be able to reset it. You will have to call the office and they will tell you "It is a thirty amp pedestal, designed to deliver up to thirty amps of service. Therefore, you need to disconnect one of those cords." Your trick won't work everywhere.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
