Bill_Satellite
Jun 09, 2016Explorer II
TNGW1500SE wrote:
Why not just upgrade the RV to 50 amps? I did it on my TT. You can always adapt it to a 30 if that's all the is at the campsite. I added a new panel and used the old panel as a sub. I feed the old panel off a 30 amp breaker in the new panel using the old 30 amp cord. Then I removed the 20 amp A/C from the old panel and put it on a 20 amp breaker on the new panel. The most expensive part was the wire but if you watch Craigslist, you might find a RV extension cord that you can use if you cut the female end off of it. If you get the A/C off the 30 amp panel, that frees up a bunch of amps for other things. It solved any lack of amperage issues we had in the TT. I may do it again in the class A, but for now it's ok. I'm in the middle of other projects!!!!!
I am not sure that I understand what you did, but 50amp service provides up to 100 amp (12,000 watts) not 30 amp plus 20 amp (50 total amps, 6000 watts).
Upgrading a 30 amp coach to a 50 amp coach can certainly be done but the total price required to do so may catch some owners off guard.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
